Introdução
The battery is the main source of power to the computer. Often times batteries will lose charge and need to be replaced. If the laptop won't turn on without the power cable, use this guide to replace the battery.
O que você precisa
Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
Quase terminado!
Conclusão
