Ir para o conteúdo principal
Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement
O que você precisa
  1. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement, Back Cover: passo 1, imagem 1 %32
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: passo 2, imagem 1 %32 Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: passo 2, imagem 2 %32
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: passo 3, imagem 1 %32 Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: passo 3, imagem 2 %32 Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: passo 3, imagem 3 %32
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: passo 4, imagem 1 %32
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement, Hard Drive: passo 5, imagem 1 %32
    • Slide the hard drive out of the SATA port and remove it from the device.
  6. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement, USB Port Plate: passo 6, imagem 1 %32
    • Remove the two 5.0 mm Phillips #1 screws shown.
    • Remove the two 3.0 mm Phillips #1 screws shown.
  7. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: passo 7, imagem 1 %32
    • Using a plastic opening tool, pry open the hinge shown until your fingers can fit under it.
  8. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: passo 8, imagem 1 %32
    • Pull the hinge the rest of the way up.
  9. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: passo 9, imagem 1 %32
    • Disconnect the plate from the shown connector. The USB port plate is now disconnected from your device.
Conclusão
Kevin Kochanek
Membro desde: 11/06/18
181 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 Membro de UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 201
