Ir para o conteúdo principal
Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement
O que você precisa
  1. Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement: passo 2, imagem 1 %32 Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement: passo 2, imagem 2 %32
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement: passo 3, imagem 1 %32 Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement: passo 3, imagem 2 %32 Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement: passo 3, imagem 3 %32
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement: passo 4, imagem 1 %32
    • Lift off the cover and remove the back cover from the device.
Conclusão
Equipe
USF Tampa, Team S10-G3, Thompson Fall 2017 Membro de USF Tampa, Team S10-G3, Thompson Fall 2017
USFT-THOMPSON-F17S10G3
Membros da 4
Autoria de 6 guias
Um comentário
thank you. this guide was a hugh help to me.
Stephanie Square - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 60
Duração total: 21,282
