Ir para o conteúdo principal
Asus Vivobook Max X541SA-PD0703X Track Pad Replacement
O que você precisa
  1. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement, Keyboard: passo 1, imagem 1 %32
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: passo 2, imagem 1 %32
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: passo 3, imagem 1 %32 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: passo 3, imagem 2 %32
    • Using a plastic opening tool, pry up the palm rest form the bottom half of the laptop.
    • Ribbon cables connect the two half so don't remove completely.
  4. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: passo 4, imagem 1 %32 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: passo 4, imagem 2 %32 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: passo 4, imagem 3 %32
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: passo 5, imagem 1 %32
    • Take the keyboard half of the laptop and place it in front of you so that they keys are facing down.
  6. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: passo 6, imagem 1 %32
    • Remove the three 3mm Phillips #0 screws from the touchpad.
  7. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: passo 7, imagem 1 %32
    • Use a spudger to flip up the retaining flap on the touch pad ribbon cable ZIF socket.
    • Pull the ribbon out of the socket.
  8. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: passo 8, imagem 1 %32 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: passo 8, imagem 2 %32
    • Remove the touchpad.
Conclusão
Hetvi Mehta
Membro desde: 02/22/18
781 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G4, Cagle Spring 2018 Membro de USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 479
