Ir para o conteúdo principal
Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement
O que você precisa
  1. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 3, imagem 1 %32 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 3, imagem 2 %32 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 3, imagem 3 %32
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 4, imagem 1 %32 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 4, imagem 2 %32 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 4, imagem 3 %32
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 6, imagem 1 %32 Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 6, imagem 2 %32
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Hard Drive Replacement: passo 7, imagem 1 %32
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S1-G4, Cagle Spring 2018 Membro de USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
Membros da 4
Autoria de 7 guias
2 comentários
is it possible to upgrade the hard drive of any laptop? from 500GB to 1T?
kevin ross s. rosento - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 2,574
