Ir para o conteúdo principal
Asus Vivobook Max X541SA-PD0703X Battery Replacement
O que você precisa
  1. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Hard Drive: passo 1, imagem 1 %32
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 2, imagem 1 %32
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 3, imagem 1 %32 Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 3, imagem 2 %32 Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 3, imagem 3 %32
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 4, imagem 1 %32 Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 4, imagem 2 %32 Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 4, imagem 3 %32
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 5, imagem 1 %32
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 6, imagem 1 %32 Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 6, imagem 2 %32
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 7, imagem 1 %32
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Disc Drive: passo 8, imagem 1 %32
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
  9. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Motherboard: passo 9, imagem 1 %32 Asus Vivobook Max X541SA-PD0703X Battery Replacement, Motherboard: passo 9, imagem 2 %32
    • Remove the three 6mm Phillips #0 screws from the fan shroud.
    • Remove the shroud from the motherboard.
  10. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 10, imagem 1 %32
    • Pull the metal casing to the right.
    • Be careful when pulling the case because it may break the motherboard.
  11. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 11, imagem 1 %32 Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 11, imagem 2 %32
    • There is a wire attached to the screen display.
    • Peel the sticker and disconnect it from the motherboard.
  12. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 12, imagem 1 %32
    • Remove the plastic covering off of the motherboard.
  13. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 13, imagem 1 %32
    • Remove the five 6mm Phillips #0 screws from the motherboard.
  14. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 14, imagem 1 %32 Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 14, imagem 2 %32
    • Remove the cables connected to the motherboard by unplugging them using a plastic opening tool, or by hand.
  15. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 15, imagem 1 %32
    • Pull the motherboard to the right and lift up.
  16. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Battery: passo 16, imagem 1 %32
    • Remove the 6mm Phillips #0 screw from the battery bracket.
  17. Asus Vivobook Max X541SA-PD0703X Battery Replacement: passo 17, imagem 1 %32
    • Use a plastic opening tool to remove the battery from the laptop.
Conclusão
3 outras pessoas executaram este guia.
Hetvi Mehta
Membro desde: 02/22/18
781 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G4, Cagle Spring 2018 Membro de USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
Membros da 4
Autoria de 7 guias
4 comentários
Finished so simple, guide was easy to follow. Thank you
Forever R Holdings - Responder
Who was the idiot who designed this laptop? Remove the motherboard to replace the battery? Unbelievable.
Greg Worrel - Responder
I have a dead cmos battery and it seems i need to replace the whole battery
Wint3r xxx -
Sir how do I replace my cmos battery? Is it integrated with the battery. I also have Asus Vivobook Max X541SA-PD0703X
Wint3r xxx - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 5,109
