Introdução
This guide provides instructions for replacing the motherboard on an Asus Vivobook Flip 14 TP410U laptop.
O que você precisa
Unplug the power cable from the laptop and assure that the laptop is completely turned off.
Use a Phillips #00 screwdriver to remove the eleven 12.8 mm screws from the bottom cover.
Insert the opening tool in between the back cover and keyboard.
Apply pressure and undo all of the "snaps" that are connecting the back cover and keyboard.
Remove each cable connected to the HD audio, Wi-Fi card, and touchpad.
Unscrew and remove the ten 6.4 mm Phillips #00 screws that are outlined in the photo.
Remove the connector connecting the front display to the motherboard.
Remove the motherboard by pulling the motherboard away from the I/O Ports on the side of the laptop.
Uma outra pessoa concluiu este guia.
