Ir para o conteúdo principal
Asus VivoTab Smart Motherboard Replacement
O que você precisa
  1. Asus VivoTab Smart Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Asus VivoTab Smart Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Asus VivoTab Smart Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Power off the device before you begin disassembly.
    • Place the device face down on a flat surface.
    • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
  2. Asus VivoTab Smart Motherboard Replacement: passo 2, imagem 1 %32 Asus VivoTab Smart Motherboard Replacement: passo 2, imagem 2 %32 Asus VivoTab Smart Motherboard Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Unplug the ribbon that connects to the camera by pulling outward on it with tweezers.
    • Remove the silver plate that sits on top of the camera lens.
  3. Asus VivoTab Smart Motherboard Replacement: passo 3, imagem 1 %32 Asus VivoTab Smart Motherboard Replacement: passo 3, imagem 2 %32 Asus VivoTab Smart Motherboard Replacement: passo 3, imagem 3 %32
    • Use tweezers to grab the speaker cable near the white plug and pull to disconnect it.
  4. Asus VivoTab Smart Motherboard Replacement: passo 4, imagem 1 %32 Asus VivoTab Smart Motherboard Replacement: passo 4, imagem 2 %32
    • Gently pull outward on the ribbon to with tweezers to disconnect it.
  5. Asus VivoTab Smart Motherboard Replacement: passo 5, imagem 1 %32 Asus VivoTab Smart Motherboard Replacement: passo 5, imagem 2 %32 Asus VivoTab Smart Motherboard Replacement: passo 5, imagem 3 %32
    • Peel back the tape covering the ribbons.
  6. Asus VivoTab Smart Motherboard Replacement: passo 6, imagem 1 %32 Asus VivoTab Smart Motherboard Replacement: passo 6, imagem 2 %32 Asus VivoTab Smart Motherboard Replacement: passo 6, imagem 3 %32
    • Unplug the 3 ribbons by pulling outward on them with a pair of tweezers.
  7. Asus VivoTab Smart Motherboard Replacement: passo 7, imagem 1 %32 Asus VivoTab Smart Motherboard Replacement: passo 7, imagem 2 %32 Asus VivoTab Smart Motherboard Replacement: passo 7, imagem 3 %32
    • Remove two 2.7 mm Phillips #00 screws holding down the pressure plate.
    • Use tweezers to lift back the battery connector, which is located directly under the pressure plate.
  8. Asus VivoTab Smart Motherboard Replacement: passo 8, imagem 1 %32 Asus VivoTab Smart Motherboard Replacement: passo 8, imagem 2 %32
    • Remove seven 3.7 mm Phillips #00 screws.
    • Remove one 2.7 mm Phillips #00 screw.
  9. Asus VivoTab Smart Motherboard Replacement: passo 9, imagem 1 %32 Asus VivoTab Smart Motherboard Replacement: passo 9, imagem 2 %32
    • Slide the tweezers under the motherboard and lift up to remove the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Les Clarke
Membro desde: 10/06/16
288 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 2-4, Sullivan Fall 2016 Membro de USF Tampa, Team 2-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 1,304
