Ir para o conteúdo principal
Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly
O que você precisa
  1. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly, Keyboard: passo 1, imagem 1 %32
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly: passo 2, imagem 1 %32
    • Flip the laptop over so the back panel is displayed.
  3. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly: passo 3, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly: passo 4, imagem 1 %32
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly: passo 5, imagem 1 %32
    • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
  6. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly: passo 6, imagem 1 %32
    • Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
  7. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly, Battery: passo 7, imagem 1 %32
    • Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
    • The batteries should all be connected to one another and come out of the device as a single unit.
    • Be careful not to rip any of the black plastic covering the batteries. Exposed battery parts can lead to explosions. If the case is ripped, re-wrap them, or properly dispose of them. Do not reuse them.
  8. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly, Disk Drive: passo 8, imagem 1 %32
    • The Disk Drive is located within the upper right hand corner of the laptop.
  9. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly: passo 9, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the two screws (5.6 mm) around the disc drive.
    • Note which screws go where. The two smaller screws fasten onto the disc drive, while the three larger screws secure the drive on the outside.
  10. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly: passo 10, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the two screws (2.7 mm) on the side of the disc drive fastener.
  11. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly: passo 11, imagem 1 %32
    • After removing the seven screws, lift the metal fastener from the disc drive with the plastic opening tool.
  12. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly: passo 12, imagem 1 %32
    • Slide the disc drive to the right, removing it from the laptop case.
  13. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly, Hard Drive: passo 13, imagem 1 %32
    • The Hard Drive is located in the bottom right hand corner. It should be the device covered in black foam.
    • Do not remove the foam. It's anti-static foam and protects the hard drive from static and any bumps as you move around your device.
  14. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly: passo 14, imagem 1 %32
    • Using the Phillips #0 screwdriver, unscrew the four (5.7cm) screws around the hard drive.
  15. Asus VivoBook X540SA-BPD0602V Hard Drive Removal Disassembly: passo 15, imagem 1 %32
    • Using the blue plastic opening tool in the iFixit tool kit, slide the hard drive to the right to remove it from the case.
    • Some models don't come with a foam insert. This will cause a bit of a rattle if you're replacing the old hard drive with an SSD drive.
Conclusão
Uma outra pessoa concluiu este guia.
Jessica Browne
Membro desde: 10/18/17
978 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S1-G111, Cagle Fall 2017 Membro de USF Tampa, Team S1-G111, Cagle Fall 2017
USFT-CAGLE-F17S1G111
Membros da 5
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 47
Duração total: 3,556
