Introdução
Welcome to this step-by-step guide on how to upgrade the RAM (memory) in your Asus VivoBook X540N. Adding more RAM to your laptop can significantly boost its performance, making it more responsive when running multiple applications or working with large files. In this simple and easy-to-follow tutorial, we'll walk you through the process of removing and replacing the RAM module. Just follow these clear instructions, and you'll have your laptop running smoother in no time.
O que você precisa
To reassemble your device, follow these instructions in reverse order
Um comentário
i have a sonic master asus pc with a motherboard model is X540NA 1.0 i have 4gb ram DDR3 how i can upgrade, pls respond quickly i need this
