Ir para o conteúdo principal
Asus VivoBook X202E-DB21T Trackpad Replacement
O que você precisa
  1. Asus VivoBook X202E-DB21T Trackpad Replacement, Battery: passo 1, imagem 1 %32 Asus VivoBook X202E-DB21T Trackpad Replacement, Battery: passo 1, imagem 2 %32
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Trackpad Replacement: passo 2, imagem 1 %32 Asus VivoBook X202E-DB21T Trackpad Replacement: passo 2, imagem 2 %32
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Trackpad Replacement: passo 3, imagem 1 %32 Asus VivoBook X202E-DB21T Trackpad Replacement: passo 3, imagem 2 %32
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Trackpad Replacement: passo 4, imagem 1 %32
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Trackpad Replacement: passo 5, imagem 1 %32
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T Trackpad Replacement, Trackpad: passo 6, imagem 1 %32 Asus VivoBook X202E-DB21T Trackpad Replacement, Trackpad: passo 6, imagem 2 %32
    • Remove the ten 4mm screws using a Phillips #00.
  7. Asus VivoBook X202E-DB21T Trackpad Replacement: passo 7, imagem 1 %32
    • Carefully remove the metal plate from the laptop.
  8. Asus VivoBook X202E-DB21T Trackpad Replacement: passo 8, imagem 1 %32
    • Remove the four 5mm screws from the trackpad using a Phillips #00.
  9. Asus VivoBook X202E-DB21T Trackpad Replacement: passo 9, imagem 1 %32
    • Remove the trackpad from the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 286
