Introdução
The motherboard is the brain of the computer. It controls everything from image generation to file access and everything in-between. This component can get damaged due to liquid exposure, drops from tall heights, and insect infestations. Take care to make sure the motherboard is disconnected from power before starting.
O que você precisa
Flip the device such that the labels are on top.
Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
Use the same screwdriver to remove the four 5mm screws in the front.
Use the same screwdriver to remove the single 9mm screw in the center.
Uma outra pessoa concluiu este guia.
