Ir para o conteúdo principal
Asus VivoBook X202E-DB21T CMOS Battery Replacement
O que você precisa
  1. Asus VivoBook X202E-DB21T CMOS Battery Replacement, Battery: passo 1, imagem 1 %32 Asus VivoBook X202E-DB21T CMOS Battery Replacement, Battery: passo 1, imagem 2 %32
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 2, imagem 1 %32 Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 2, imagem 2 %32
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 3, imagem 1 %32 Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 3, imagem 2 %32
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 4, imagem 1 %32
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 5, imagem 1 %32
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T CMOS Battery Replacement, CMOS Battery: passo 6, imagem 1 %32 Asus VivoBook X202E-DB21T CMOS Battery Replacement, CMOS Battery: passo 6, imagem 2 %32
    • Unplug and remove the CMOS battery.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 83
Duração total: 6,339
