Ir para o conteúdo principal
Asus VivoBook S200E-RHI3T73 Screen Replacement
O que você precisa
  1. Asus VivoBook S200E-RHI3T73 Screen Replacement, Screen: passo 1, imagem 1 %32
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the five black 80mm Phillips #0 screws.
    • Remove the four black 50mm Phillips #0 screws.
  2. Asus VivoBook S200E-RHI3T73 Screen Replacement: passo 2, imagem 1 %32
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  3. Asus VivoBook S200E-RHI3T73 Screen Replacement: passo 3, imagem 1 %32
    • Use a metal spudger to remove the clear screen protector from its backing.
    • Apply ample force along the bottom of the screen protector.
  4. Asus VivoBook S200E-RHI3T73 Screen Replacement: passo 4, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the four 2mm silver screws located at each of the four corners of the screen.
  5. Asus VivoBook S200E-RHI3T73 Screen Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently lift the screen up and over.
    • Use tweezers to remove the EX2 LVDS connector cable that connects the screen and the laptop.
    • Remove the screen.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 2,068
