Ir para o conteúdo principal
Asus VivoBook S200E-RHI3T73 Keyboard Replacement
O que você precisa
  1. Asus VivoBook S200E-RHI3T73 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the nine 50mm screws and lift the panel.
    • Be aware of sharp metal edges once the panel is removed.
  2. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 2, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the twelve 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  3. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 3, imagem 1 %32 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 3, imagem 2 %32 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the Phillips #0 screwdriver to remove the five 5mm screws around the fan.
    • Use the precision tweezers to unplug the fan cords.
    • Be cautious of pulling the cords.
  4. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 4, imagem 1 %32 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 4, imagem 2 %32 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 4, imagem 3 %32
    • Use the Phillips#0 screwdriver to unscrew the 3.5mm screws from around the motherboard and the 6mm screws from around the PCB.
    • Double check for unloosened screws. Bending the boards can damage the hardware.
  5. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 5, imagem 1 %32 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 5, imagem 2 %32
    • Use the Phillips#0 screwdriver to remove the 50mm screws on the boarder of the metal panel.
    • Be cautious of sharp metal edges.
    • Carefully remove the panel. Without care it will bend and be difficult to reassemble.
  6. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: passo 6, imagem 1 %32
    • Using the Phillips#0 screwdriver, remove the 50mm screws surrounding the keyboard.
    • Gently remove the keyboard.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 607
