Introdução
If the laptop powers on when the charger is connected, but fails to power on or stay on when disconnected, then your battery may need to be replaced. This guide will show you how to replace the battery.
O que você precisa
Use a metal spudger to pry the bottom panel open.
Lift the back panel to expose the inside of the laptop.
3 outras pessoas executaram este guia.
