Introdução
This guide can help fix issues such as file corruption, irregular booting, or can be used to upgrade the hard drive. If the drive is defective, follow this guide to replace the existing hard drive.
O que você precisa
Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
