Pular para o conteúdo principal
Introdução
This guide can help fix issues such as file corruption, irregular booting, or can be used to upgrade the hard drive. If the drive is defective, follow this guide to replace the existing hard drive.
Peças
Nenhum componente especificado.
  1. Before doing a repair or replacement make sure the laptop is fully shut off. Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  2. Insert the flat edge of the opening tool in between the back casing to remove the back casing. Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
    • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Using the JIS #0 Screwdriver, remove the five  3.0 mm screws that hold down the hard drive casing. Using the JIS #0 Screwdriver, remove the five  3.0 mm screws that hold down the hard drive casing.
    • Using the JIS #0 Screwdriver, remove the five 3.0 mm screws that hold down the hard drive casing.
  4. Lift the hard drive up and remove the power supply cable connected to it. Make sure to pull on the plastic head and not the actual wires to prevent tearing them. Make sure to pull on the plastic head and not the actual wires to prevent tearing them.
    • Lift the hard drive up and remove the power supply cable connected to it.
    • Make sure to pull on the plastic head and not the actual wires to prevent tearing them.
  5. Carefully peel back and remove the plastic hard drive cover to reveal the two 3.0 mm screws on the hard drive casing. Using a JIS #0 screwdriver, unscrew the two 3.0 mm screws on the side of the metal casing to remove the hard drive itself. Using a JIS #0 screwdriver, unscrew the two 3.0 mm screws on the side of the metal casing to remove the hard drive itself.
    • Carefully peel back and remove the plastic hard drive cover to reveal the two 3.0 mm screws on the hard drive casing.
    • Using a JIS #0 screwdriver, unscrew the two 3.0 mm screws on the side of the metal casing to remove the hard drive itself.
Conclusão
2 outras pessoas concluíram este guia.
Deric Wright
Membro desde: 14-02-2018
636 reputação
3 Guias de autoria
Equipe
USF Tampa, Team S5-G5, Eyestone Spring 2018 Membro de USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 Membros
5 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 29
Todo: 252
