Ir para o conteúdo principal
Asus VivoBook Q302LA-BHI3T09 Display Replacement
O que você precisa
  1. Asus VivoBook Q302LA-BHI3T09 Display Replacement, Display: passo 1, imagem 1 %32 Asus VivoBook Q302LA-BHI3T09 Display Replacement, Display: passo 1, imagem 2 %32
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  2. Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 2, imagem 1 %32 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 2, imagem 2 %32
    • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 3, imagem 1 %32 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 3, imagem 2 %32
    • Using the JIS #0 Screwdriver, remove the five 3.0 mm screws that hold down the hard drive casing.
  4. Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 4, imagem 1 %32 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 4, imagem 2 %32 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 4, imagem 3 %32
    • Lift the hard drive up and remove the power supply cable connected to it.
    • Make sure to pull on the plastic head and not the actual wires to prevent tearing them.
  5. Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 5, imagem 1 %32 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 5, imagem 2 %32
    • Disconnect the white and black wires attached to the Wi-Fi chip.
  6. Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 6, imagem 1 %32 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 6, imagem 2 %32 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 6, imagem 3 %32
    • Remove the two adapters connecting the display to the motherboard by pulling the black plastic straps directly upwards.
  7. Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 7, imagem 1 %32 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 7, imagem 2 %32 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 7, imagem 3 %32
    • Use the JIS #0 screwdriver to remove the five 5.0 mm screws connecting the display to the rest of the laptop.
Conclusão
Deric Wright
Membro desde: 02/14/18
636 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S5-G5, Eyestone Spring 2018 Membro de USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 252
