Ir para o conteúdo principal
Asus VivoBook Q200E-BSI3T08 Keyboard Replacement
O que você precisa
  1. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 3, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Motherboard: passo 4, imagem 1 %32
    • Locate the motherboard under the cooling fan.
  5. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 5, imagem 1 %32
    • Unscrew the two 5.9mm screws on the PCB board with a Phillips #0 screwdriver.
  6. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 6, imagem 1 %32
    • Remove the PCB board from the motherboard.
  7. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 7, imagem 1 %32
    • Unscrew the four 5.9mm hard drive bracket screws with a Phillips #0 screwdriver.
  8. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 8, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 8, imagem 2 %32
    • Unscrew the four 5.9mm screws with a Phillips #0 screwdriver.
    • Next, carefully lift the LAN bracket out of the slot.
  9. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 9, imagem 1 %32
    • Remove the five 5.9mm screws holding the motherboard in place with a Phillips #0 screwdriver.
    • Remove the five 3.5mm screws holding the motherboard with a Phillips #00 screwdriver.
  10. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 10, imagem 1 %32
    • Carefully lift the motherboard up out of the slot.
  11. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 11, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 11, imagem 2 %32
    • Locate and unplug the power bus from the motherboard.
    • The motherboard can now be replaced.
  12. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Battery: passo 12, imagem 1 %32
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  13. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 13, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 13, imagem 2 %32 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 13, imagem 3 %32
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  14. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 14, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 14, imagem 2 %32
    • Now just lift the battery out of place.
  15. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Trackpad: passo 15, imagem 1 %32
    • Disconnect the small blue TP(trackpad) labeled data bus.
  16. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 16, imagem 1 %32
    • Identify the ten 2.94mm screws on the metal bracket.
  17. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 17, imagem 1 %32
    • Unscrew the ten 2.94mm screws with the Philips #00 Head.
  18. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 18, imagem 1 %32
    • Remove all of the metallic tape holding the metal bracket to the components surrounding it.
  19. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 19, imagem 1 %32
    • Lift the metal bracket away from the laptop.
  20. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 20, imagem 1 %32
    • Unscrew the four 3.5mm screws with Phillips #00 Head.
    • This black plastic panel holds the trackpad in place.
  21. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 21, imagem 1 %32
    • Lift the trackpad up from the laptop and slide it out of the housing.
  22. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Cooling Fan: passo 22, imagem 1 %32
    • Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
  23. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 23, imagem 1 %32
    • Unplug the power bus for the fan.
  24. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 24, imagem 1 %32
    • Lift up and remove the cooling fan from the slot.
  25. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Keyboard: passo 25, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Keyboard: passo 25, imagem 2 %32
    • Next, unscrew the two 4.9mm hinge screws with a Phillips #00 screwdriver.
  26. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 26, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 26, imagem 2 %32
    • Remove the ten 4.9mm screws holding the metal keyboard panel in place, using a Phillips #00 screwdriver.
    • Carefully lift the metal keyboard panel out of the slot.
  27. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 27, imagem 1 %32
    • Pull the display hinges back in order to remove the metal keyboard panel.
  28. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 28, imagem 1 %32
    • Carefully pry and loosen the keyboard from the slot.
  29. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 29, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: passo 29, imagem 2 %32
    • Carefully lift the keyboard out of the slot.
Conclusão
Uma outra pessoa concluiu este guia.
Mitchell Jackson
Membro desde: 05/17/17
742 Reputação
Autoria de 7 guias
Equipe
IUPUI, Team S4-G4, Wilson Summer 2017 Membro de IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 14
Duração total: 2,228
