Ir para o conteúdo principal
Asus VivoBook Q200E-BSI3T08 Display Replacement
O que você precisa
    1. Asus VivoBook Q200E-BSI3T08 Display Replacement, Display: passo 1, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Display Replacement, Display: passo 1, imagem 2 %32
      • First open the laptop and place it so that you have access to the side of the display.
      • Next you want to place the laptop in a position where you have easy access to the display.
      • Use a metal or a plastic prying tool to split the front and back of the display.
      • Start on the side and work your way around.
      Pergunte ao FixBot
      Comentar
    2. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 2, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 2, imagem 2 %32
      • Pull the clear plastic display down from the bottom right and left.
      • If pulled from the top you might crack the actual plastic.
      Pergunte ao FixBot
      Comentar
    3. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 3, imagem 1 %32
      • Remove the two 2.8mm screws on the top right and top left of the screen using a Phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 4, imagem 1 %32
      • Remove the two 2.8 screws on the bottom right and left using a Phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 5, imagem 1 %32
      • Once the screws are removed you should be able to move the display down. Be careful as there is a connection to the motherboard which will need to be removed.
      Pergunte ao FixBot
      Comentar
    6. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 6, imagem 1 %32
      • Here is a picture of the connection that needs to be removed to free the display.
      • Pull connection from the plastic on the sides not the wires as these are fragile.
      Pergunte ao FixBot
      Comentar
    7. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 7, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 7, imagem 2 %32
      • Once this connection is removed here's what that should look.
      Pergunte ao FixBot
      Comentar
    8. Asus VivoBook Q200E-BSI3T08 Display Replacement: passo 8, imagem 1 %32
      • Remove display and place your new one in it's place.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
IUPUI, Team S4-G4, Wilson Summer 2017 Membro de IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 Membros
Autoria de 84 guias
1Comentário do guia
You are suppose to remove the hinge/screen assembly from the laptop chasis before starting step 1, if you don't you will break the digitizer author please fix the guide
Nicholas Chan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 24
Últimos 30 dias: 59
Ao todo: 2,230
