Ir para o conteúdo principal
Asus VivoBook Q200E-BSI3T08 Battery Replacement
O que você precisa
  1. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 2, imagem 1 %32
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 3, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 5, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 5, imagem 2 %32 Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 5, imagem 3 %32
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 6, imagem 1 %32 Asus VivoBook Q200E-BSI3T08 Battery Replacement: passo 6, imagem 2 %32
    • Now just lift the battery out of place.
Conclusão
14 outras pessoas executaram este guia.
Maxim
Membro desde: 01/21/15
462 Reputação
Autoria de 1 guia
Equipe
UWT Liner: Group 6 Membro de UWT Liner: Group 6
Community
3 Membros
1 Guia de autoria
2Comentários do guia
Super helpful instructions. Especially mentioning which screws were different sizes, so I knew to keep the 3 different sizes for the back cover separated and noted which sizes went back where. Many thanks!
Albert Einstein - Responder
Great guide. Thanks!
weston.fisher - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 38
Ao todo: 7,660
