Ir para o conteúdo principal
Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement
O que você precisa
  1. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: passo 3, imagem 1 %32 Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: passo 3, imagem 2 %32
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: passo 4, imagem 1 %32 Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: passo 5, imagem 1 %32
    • Lift and remove the battery.
  6. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32 Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement, Hard Drive: passo 6, imagem 2 %32
    • Remove four 4mm screws using a Phillips 0 screwdriver.
  7. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: passo 7, imagem 1 %32
    • Pull out hard drive bracket towards the edge of the laptop.
  8. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: passo 8, imagem 1 %32 Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: passo 8, imagem 2 %32 Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: passo 8, imagem 3 %32
    • Remove two 3mm screws using a Phillips 0 screwdriver from each sides of the hard drive bracket. The bracket should fall off after removal.
Conclusão
6 outras pessoas executaram este guia.
Bryann Tan
Membro desde: 09/25/16
877 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 16-2, Eyestone Fall 2016 Membro de USF Tampa, Team 16-2, Eyestone Fall 2016
USFT-EYESTONE-F16S16G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 5,503
