Introdução
This guide will show you how to replace a broken hard drive on the ASUS Vivobook.
O que você precisa
Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
6 outras pessoas executaram este guia.
