Introdução
Battery life of any device will eventually shorten over a period of time. This guide will show you how to replace a used battery with a brand new one.
O que você precisa
Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
5 outras pessoas executaram este guia.
4 comentários
Hey I need help with getting the battery out with Asus Vivo-Book E406SA
Need help getting the battery out of my E406sa
could you show me how to unplug the connector without breaking it?
