Ir para o conteúdo principal
Asus VivoBook Q200E-BHI3T45 Battery Replacement
O que você precisa
  1. Asus VivoBook Q200E-BHI3T45 Battery Replacement, Battery: passo 1, imagem 1 %32 Asus VivoBook Q200E-BHI3T45 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 Battery Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 Battery Replacement: passo 3, imagem 1 %32 Asus VivoBook Q200E-BHI3T45 Battery Replacement: passo 3, imagem 2 %32
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 Battery Replacement: passo 4, imagem 1 %32 Asus VivoBook Q200E-BHI3T45 Battery Replacement: passo 4, imagem 2 %32
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 Battery Replacement: passo 5, imagem 1 %32
    • Lift and remove the battery.
Conclusão
5 outras pessoas executaram este guia.
Bryann Tan
Membro desde: 09/25/16
877 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 16-2, Eyestone Fall 2016 Membro de USF Tampa, Team 16-2, Eyestone Fall 2016
USFT-EYESTONE-F16S16G2
Membros da 3
Autoria de 6 guias
4 comentários
Hey I need help with getting the battery out with Asus Vivo-Book E406SA
James Bruzo - Responder
hi, i need a complete case for asus vivobook Q200E. Any help please
murphy - Responder
Need help getting the battery out of my E406sa
Patrick Flynn - Responder
could you show me how to unplug the connector without breaking it?
Deng Daniel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 36
Duração total: 15,312
