Ir para o conteúdo principal
Asus VivoBook Max X541UV-BH71-CB Battery Replacement
O que você precisa
  1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop upside down so the back of the laptop faces you.
  2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 2, imagem 1 %32 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 2, imagem 2 %32 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 2, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the ten 1.2 mm screws attached to the back cover of the laptop.
  3. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 3, imagem 1 %32 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 3, imagem 2 %32 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 3, imagem 3 %32
    • Turn the laptop upright, then open the laptop so the screen faces you.
    • Use a prying tool between the keyboard and bottom grooves to partially remove the laptop backing.
    • Do not completely remove the laptop backing because there are ribbon cables connecting the two halves.
    • It is recommended to use a plastic prying tool rather than a metal prying tool because it could potentially damage the internals of the laptop.
  4. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 4, imagem 1 %32 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 4, imagem 2 %32 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 4, imagem 3 %32
    • Flip the retaining flaps on both keyboard ribbon cable ZIF sockets, then carefully pull the ribbon cables out of their sockets.
    • Carefully remove the keyboard panel from the base and set it aside.
  5. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 5, imagem 1 %32 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 5, imagem 2 %32 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 5, imagem 3 %32
    • Remove the two 1.2 mm screws holding the battery in place using the Phillips #00 screwdriver.
  6. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 6, imagem 1 %32 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 6, imagem 2 %32 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: passo 6, imagem 3 %32
    • Carefully remove the battery using a plastic opening tool.
Conclusão
Uma outra pessoa concluiu este guia.
Vivek Rana
Membro desde: 09/11/21
169 Reputação
Autoria de 1 guia
Equipe
Um comentário
Does anybody has a link to buy the battery replacement? Either original or generic. Thank you!
nea-k nanea - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 75
Duração total: 2,123
