Ir para o conteúdo principal
Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement
O que você precisa
  1. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement, Hard Disk Drive: passo 1, imagem 1 %32
    • Disconnect laptop from the power supply.
  2. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the ten 6.4 mm screws from the bottom cover.
  3. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: passo 3, imagem 1 %32 Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: passo 3, imagem 2 %32
    • Use a metal or nylon spudger to pry open the back cover on all sides.
    • Remove the back cover to access the inside where the hard disk drive is located.
  4. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: passo 4, imagem 1 %32
    • Locate the hard-drive.
    • Disconnect the hard disk drive from its connectors, and remove the drive.
    • Place the new HDD in the same location and orientation.
Conclusão
Uma outra pessoa concluiu este guia.
Justin Martel
Membro desde: 03/22/22
159 Reputação
Autoria de 1 guia
Equipe
Um comentário
Hey, do you by any chance have the reference for the battery in the Asus TP410U ? Thank you!
Matt JBOM - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 1,669
