Ir para o conteúdo principal
Asus VivoBook E203MA-TBCL432B TrackPad Replacement
O que você precisa
  1. Asus VivoBook E203MA-TBCL432B TrackPad Replacement, Back Panel: passo 1, imagem 1 %32
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 2, imagem 1 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 2, imagem 2 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 2, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 3, imagem 1 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 3, imagem 2 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 3, imagem 3 %32
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B TrackPad Replacement, Battery: passo 4, imagem 1 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement, Battery: passo 4, imagem 2 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement, Battery: passo 4, imagem 3 %32
    • Now that the back panel is removed you can clearly see the battery and all of its connectors.
    • Begin by removing the silver ribbon cable along the back of the battery.
    • To disconnect it from the motherboard, lift the black tab on the Zero Insertion Force (ZIF) connector up and pull the cable away using the blue tab.
    • Disconnect the ribbon cable from the left side in the same way.
  5. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 5, imagem 1 %32
    • Remove the red and black wire along the bottom of the battery.
    • This does not need to be disconnected, only removed from the clamps along the bottom of the battery.
  6. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 6, imagem 1 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 6, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws located at the top and left side of the battery.
  7. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 7, imagem 1 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 7, imagem 2 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 7, imagem 3 %32
    • Gently lift the battery being mindful of the one cable still connected to the motherboard.
    • With the battery lifted, pull the remaining connector going to the motherboard up, it should come out with little force.
  8. Asus VivoBook E203MA-TBCL432B TrackPad Replacement, TrackPad: passo 8, imagem 1 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement, TrackPad: passo 8, imagem 2 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement, TrackPad: passo 8, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Insert the iFixit tool underneath the cable that is attached to the trackpad to unclip the cable.
    • Using the reverse tweezers, remove the ribbon cable and the tape that is attached to the trackpad.
  9. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 9, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the three 2.0 mm screws above the trackpad.
  10. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 10, imagem 1 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 10, imagem 2 %32 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: passo 10, imagem 3 %32
    • Insert the iFixit opening tool under the frame that surrounds the trackpad and carefully pry the frame of the trackpad up.
    • Now that the track pad is lifted up, gently slide it out by pulling it towards the hinges.
Conclusão
Khadijah Sulail
Membro desde: 11/16/19
415 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S3-G3, Wilson Fall 2019 Membro de IUPUI, Team S3-G3, Wilson Fall 2019
IUPUI-WILSON-F19S3G3
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 1,019
