Ir para o conteúdo principal
Asus VivoBook E203MA-TBCL432B Power Button Replacement
O que você precisa
  1. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Back Panel: passo 1, imagem 1 %32
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 2, imagem 1 %32 Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 2, imagem 2 %32 Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 2, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 3, imagem 1 %32 Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 3, imagem 2 %32 Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 3, imagem 3 %32
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: passo 4, imagem 1 %32 Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: passo 4, imagem 2 %32
    • Remove the single connector by first pulling back the white tab and then pulling the connector out with the blue tab.
  5. Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 5, imagem 1 %32 Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 5, imagem 2 %32
    • Remove the single 2 mm screw with a Phillips #0 screwdriver.
  6. Asus VivoBook E203MA-TBCL432B Power Button Replacement: passo 6, imagem 1 %32
    • Now that the power button component is free, lift it up and out of the laptop.
Conclusão
Jacob Aubertine
Membro desde: 03/21/19
470 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 889
