Introdução
If your headphone jack or USB port no longer work properly, you can replace them by following this guide. This replacement requires only a standard Phillips #0 screwdriver and a plastic opening tool. The screwdriver is used to remove the screws on the bottom panel of the laptop and the screws on the headphone jack/USB port circuit board. This is a simple replacement and should not require any additional knowledge or information.
O que você precisa
Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
Insert the iFixit opening tool in between the back panel and the rest of the laptop.
With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
Disconnect the ribbon cable located above the battery.
Flip up the locking tab on the Zero Insertion Force (ZIF) connector, then slide the cable away.
