Ir para o conteúdo principal
Asus V6800V Keyboard Replacement
O que você precisa
  1. Asus V6800V Keyboard Replacement, Battery: passo 1, imagem 1 %32 Asus V6800V Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Keyboard Replacement, Keyboard: passo 2, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the two screws from the case.
    • These screws should have a "K" symbol next to them.
  3. Asus V6800V Keyboard Replacement: passo 3, imagem 1 %32 Asus V6800V Keyboard Replacement: passo 3, imagem 2 %32 Asus V6800V Keyboard Replacement: passo 3, imagem 3 %32
    • Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
    • Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
    • Once all four tabs have been released, the top half of the keyboard should be free.
  4. Asus V6800V Keyboard Replacement: passo 4, imagem 1 %32 Asus V6800V Keyboard Replacement: passo 4, imagem 2 %32
    • Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
    • Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
Conclusão
Steven
Membro desde: 06/24/10
32 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 2-9, Johann Summer 2010 Membro de Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 46
Ao todo: 5,146
