Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
Using a Phillips #0 screwdriver, remove the two screws from the case.
Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
Using a Phillips #0 screwdriver, remove the screws at the bottom of the chassis to remove the top panel.
Remove the six screws from below the keyboard with a Phillips #0 screwdriver.
Use your fingernails or a pry tool to gently separate both halves of the case. Begin at the front and work around the entire case.
Remove the internal cables from front to back.
Use your fingers to gently remove the cables from their sockets.
After separating the top and bottom halves of the case, lay them flat on the work area.
Remove the six screws (three on each side) holding the top panel of the chassis to the display with a Phillips #0 screwdriver.
Remove the display by leaving the display flat on the table and tilting the panel up (as if opening the laptop). This will shift the hinges to allow easy removal.
Separate the chassis from the display. If the screws were removed properly, it should come free.
Remove seven screws from the bezel with a Phillips #0 screwdriver.
Using a fingernail or opening tool, gently pry the bezel up from the screen.
Remove six screws from underneath the bezel with a Phillips #0 screwdriver. Two are located next to each hinge and one at each top corner.
Look behind the display. Locate the display connector.
Peel back the tape from over the connector.
Remove the connector from the display and slowly pull the cable away, peeling the tape back along the way.
Remove the small connector located near the right hinge.
The display is now completely removed and can be replaced.
Uma outra pessoa concluiu este guia.
