Ir para o conteúdo principal
Asus V6800V CD/DVD Drive Replacement
O que você precisa
  1. Asus V6800V CD/DVD Drive Replacement, Battery: passo 1, imagem 1 %32 Asus V6800V CD/DVD Drive Replacement, Battery: passo 1, imagem 2 %32
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V CD/DVD Drive Replacement, Hard Drive: passo 2, imagem 1 %32 Asus V6800V CD/DVD Drive Replacement, Hard Drive: passo 2, imagem 2 %32
    • Remove the two screws using a Phillips #0 screwdriver.
  3. Asus V6800V CD/DVD Drive Replacement: passo 3, imagem 1 %32 Asus V6800V CD/DVD Drive Replacement: passo 3, imagem 2 %32
    • Pry open the case using an iFixit opening tool.
    • Actual hard drive is not shown in the second image.
  4. Asus V6800V CD/DVD Drive Replacement: passo 4, imagem 1 %32 Asus V6800V CD/DVD Drive Replacement: passo 4, imagem 2 %32
    • The highlighted area is where your hard drive would be. Slide it out away from its slot and pull it gently to remove.
    • Second image shows what it should look like once you remove the hard drive.
  5. Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: passo 5, imagem 1 %32 Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: passo 5, imagem 2 %32
    • Remove the screw from the bottom right corner using a Phillips #0 screwdriver.
    • Insert a spudger into the hole to carefully push the CD/DVD drive out.
Conclusão
To reassemble your device, just push the new CD/DVD driver back. Then put the components back together then put the screws back in.
Jong Park
Membro desde: 06/24/10
114 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 2-9, Johann Summer 2010 Membro de Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 4,292
