Ir para o conteúdo principal
Asus V500CA-DB51T WiFi Card Replacement
O que você precisa
  1. Asus V500CA-DB51T WiFi Card Replacement, Battery: passo 1, imagem 1 %32 Asus V500CA-DB51T WiFi Card Replacement, Battery: passo 1, imagem 2 %32
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T WiFi Card Replacement: passo 2, imagem 1 %32 Asus V500CA-DB51T WiFi Card Replacement: passo 2, imagem 2 %32
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T WiFi Card Replacement: passo 3, imagem 1 %32
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T WiFi Card Replacement: passo 4, imagem 1 %32 Asus V500CA-DB51T WiFi Card Replacement: passo 4, imagem 2 %32
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T WiFi Card Replacement: passo 5, imagem 1 %32 Asus V500CA-DB51T WiFi Card Replacement: passo 5, imagem 2 %32 Asus V500CA-DB51T WiFi Card Replacement: passo 5, imagem 3 %32
    • Use the opening tool to pop up the battery away from the casing.
  6. Asus V500CA-DB51T WiFi Card Replacement, WiFi Card: passo 6, imagem 1 %32 Asus V500CA-DB51T WiFi Card Replacement, WiFi Card: passo 6, imagem 2 %32
    • Locate the section of the device that houses the WiFi Card.
    • This should be a white, square-shaped object located just above the left end of the battery.
  7. Asus V500CA-DB51T WiFi Card Replacement: passo 7, imagem 1 %32 Asus V500CA-DB51T WiFi Card Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the black and white wires that are connected to the WiFi card by gently pulling them upward with a pair of tweezers.
    • Using the tweezers, gently pull the WiFi card out away from yourself.
    • If you try pulling up you could cause damage, so be sure to slowly and gently pull the card away from yourself.
Conclusão
Galen P Garofalo
Membro desde: 10/17/17
670 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S6-G2, Rockett Fall 2017 Membro de UMass Dartmouth, Team S6-G2, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 273
