Ir para o conteúdo principal
Asus UL80VT Motherboard Replacement
O que você precisa
  1. Asus UL80VT Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop so you can see the back side.
  2. Asus UL80VT Motherboard Replacement: passo 2, imagem 1 %32 Asus UL80VT Motherboard Replacement: passo 2, imagem 2 %32
    • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
  3. Asus UL80VT Motherboard Replacement: passo 3, imagem 1 %32
    • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
  4. Asus UL80VT Motherboard Replacement, Hard Drive: passo 4, imagem 1 %32 Asus UL80VT Motherboard Replacement, Hard Drive: passo 4, imagem 2 %32 Asus UL80VT Motherboard Replacement, Hard Drive: passo 4, imagem 3 %32
    • Flip the computer over, and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
    • Lift the panel from the device.
  5. Asus UL80VT Motherboard Replacement: passo 5, imagem 1 %32 Asus UL80VT Motherboard Replacement: passo 5, imagem 2 %32
    • Slide the hard drive away from the SATA connector and remove the hard drive from the device.
  6. Asus UL80VT Motherboard Replacement, RAM: passo 6, imagem 1 %32
    • Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
  7. Asus UL80VT Motherboard Replacement: passo 7, imagem 1 %32 Asus UL80VT Motherboard Replacement: passo 7, imagem 2 %32 Asus UL80VT Motherboard Replacement: passo 7, imagem 3 %32
    • Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
  8. Asus UL80VT Motherboard Replacement, Keyboard: passo 8, imagem 1 %32 Asus UL80VT Motherboard Replacement, Keyboard: passo 8, imagem 2 %32
    • Open laptop so the keyboard is accessible.
    • Insert a plastic prying tool and push and then pull to release the keyboard from the device.
  9. Asus UL80VT Motherboard Replacement: passo 9, imagem 1 %32
    • Lift keyboard and remove ZIF connector cables.
    • Remove the keyboard from the device.
  10. Asus UL80VT Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • Remove the nine 5 mm screws using the Phillips #0 screwdriver.
  11. Asus UL80VT Motherboard Replacement: passo 11, imagem 1 %32
    • Flip the laptop over and remove nine 5 mm screws using the Phillips #0 screwdriver.
  12. Asus UL80VT Motherboard Replacement: passo 12, imagem 1 %32 Asus UL80VT Motherboard Replacement: passo 12, imagem 2 %32
    • Use the iFixit opening tool to remove the cd drive on the left of the laptop.
  13. Asus UL80VT Motherboard Replacement: passo 13, imagem 1 %32
    • Use the same tool to remove the plastic top from the laptop.
  14. Asus UL80VT Motherboard Replacement: passo 14, imagem 1 %32
    • Remove the eight 3 mm screws using the Phillips #0 screwdriver.
    • Lift up the motherboard and disconnect all wires attaching the motherboard to the rest of the computer.
  15. Asus UL80VT Motherboard Replacement: passo 15, imagem 1 %32
    • Lift the motherboard out of the laptop and remove it from the device.
Conclusão
James DellaMorte
Membro desde: 03/08/19
660 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 434
