Ir para o conteúdo principal
Asus UL30VT-X1 Battery Replacement
O que você precisa
  1. Asus UL30VT-X1 Battery Replacement, Battery: passo 1, imagem 1 %32 Asus UL30VT-X1 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over onto the back. (Second Image)
  2. Asus UL30VT-X1 Battery Replacement: passo 2, imagem 1 %32 Asus UL30VT-X1 Battery Replacement: passo 2, imagem 2 %32
    • Locate the two battery locks. (First Image)
    • The battery lock on the left will need to be unlocked first which is done by pushing the lock to the left. (Second Image)
    • A red line should show which indicates it is unlocked.
  3. Asus UL30VT-X1 Battery Replacement: passo 3, imagem 1 %32
    • Unlock the right lock by moving it to the right while simultaneously pushing upwards on the battery.
    • The battery should slide out of place.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 312
