Ir para o conteúdo principal
Asus U56E-BBL6 Optical Drive Replacement
O que você precisa
  1. Asus U56E-BBL6 Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Make sure you unplugged the laptop before you begin the replacement process.
    • Locate the battery locking tabs on the upper right and left corner.
    • Press the tabs in towards each other.
  2. Asus U56E-BBL6 Optical Drive Replacement: passo 2, imagem 1 %32
    • Pull the battery outwards to remove it.
  3. Asus U56E-BBL6 Optical Drive Replacement, Back Panel: passo 3, imagem 1 %32 Asus U56E-BBL6 Optical Drive Replacement, Back Panel: passo 3, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the screws.
  4. Asus U56E-BBL6 Optical Drive Replacement: passo 4, imagem 1 %32
    • Lift backplate and remove from the case.
  5. Asus U56E-BBL6 Optical Drive Replacement, RAM: passo 5, imagem 1 %32
    • Once inside the panel, locate your RAM sticks.
  6. Asus U56E-BBL6 Optical Drive Replacement: passo 6, imagem 1 %32 Asus U56E-BBL6 Optical Drive Replacement: passo 6, imagem 2 %32
    • This device is embedded with two RAM sticks.
    • Push the metal brackets carefully to release and remove the RAM stick .
  7. Asus U56E-BBL6 Optical Drive Replacement: passo 7, imagem 1 %32 Asus U56E-BBL6 Optical Drive Replacement: passo 7, imagem 2 %32
    • Repeat the previous step for removing the other RAM stick.
  8. Asus U56E-BBL6 Optical Drive Replacement, Keyboard: passo 8, imagem 1 %32
    • Using a Phillips #00, remove the four screws.
  9. Asus U56E-BBL6 Optical Drive Replacement: passo 9, imagem 1 %32 Asus U56E-BBL6 Optical Drive Replacement: passo 9, imagem 2 %32
  10. Asus U56E-BBL6 Optical Drive Replacement: passo 10, imagem 1 %32
    • Use a plastic opening tool around the entire edge.
    • Separate the case from the keyboard.
  11. Asus U56E-BBL6 Optical Drive Replacement: passo 11, imagem 1 %32
    • Ensure the laptop is face up for this step.
    • Gently lift the keyboard from the base of the laptop.
    • Be careful of the ribbon cables connecting the keyboard.
  12. Asus U56E-BBL6 Optical Drive Replacement: passo 12, imagem 1 %32
    • Gently tug the ribbon cables free from their slots.
  13. Asus U56E-BBL6 Optical Drive Replacement: passo 13, imagem 1 %32 Asus U56E-BBL6 Optical Drive Replacement: passo 13, imagem 2 %32
    • Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
  14. Asus U56E-BBL6 Optical Drive Replacement, Optical Drive: passo 14, imagem 1 %32
    • Using a plastic opening tool, separate the optical drive from the laptop frame.
    • Be careful to leverage the plastic opening tool against the frame and not the motherboard as this may cause damage.
  15. Asus U56E-BBL6 Optical Drive Replacement: passo 15, imagem 1 %32
    • Remove the optical drive by sliding it out from the case.
Conclusão
Josiah Allard
Membro desde: 10/26/18
733 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S2-G8, Peak Fall 2018 Membro de UMass Dartmouth, Team S2-G8, Peak Fall 2018
UMASSD-PEAK-F18S2G8
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 206
