Ir para o conteúdo principal
Asus U56E-BBL6 Keyboard Replacement
O que você precisa
  1. Asus U56E-BBL6 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Make sure you unplugged the laptop before you begin the replacement process.
    • Locate the battery locking tabs on the upper right and left corner.
    • Press the tabs in towards each other.
  2. Asus U56E-BBL6 Keyboard Replacement: passo 2, imagem 1 %32
    • Pull the battery outwards to remove it.
  3. Asus U56E-BBL6 Keyboard Replacement, Back Panel: passo 3, imagem 1 %32 Asus U56E-BBL6 Keyboard Replacement, Back Panel: passo 3, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the screws.
  4. Asus U56E-BBL6 Keyboard Replacement: passo 4, imagem 1 %32
    • Lift backplate and remove from the case.
  5. Asus U56E-BBL6 Keyboard Replacement, RAM: passo 5, imagem 1 %32
    • Once inside the panel, locate your RAM sticks.
  6. Asus U56E-BBL6 Keyboard Replacement: passo 6, imagem 1 %32 Asus U56E-BBL6 Keyboard Replacement: passo 6, imagem 2 %32
    • This device is embedded with two RAM sticks.
    • Push the metal brackets carefully to release and remove the RAM stick .
  7. Asus U56E-BBL6 Keyboard Replacement: passo 7, imagem 1 %32 Asus U56E-BBL6 Keyboard Replacement: passo 7, imagem 2 %32
    • Repeat the previous step for removing the other RAM stick.
  8. Asus U56E-BBL6 Keyboard Replacement, Keyboard: passo 8, imagem 1 %32
    • Using a Phillips #00, remove the four screws.
  9. Asus U56E-BBL6 Keyboard Replacement: passo 9, imagem 1 %32 Asus U56E-BBL6 Keyboard Replacement: passo 9, imagem 2 %32
  10. Asus U56E-BBL6 Keyboard Replacement: passo 10, imagem 1 %32
    • Use a plastic opening tool around the entire edge.
    • Separate the case from the keyboard.
  11. Asus U56E-BBL6 Keyboard Replacement: passo 11, imagem 1 %32
    • Ensure the laptop is face up for this step.
    • Gently lift the keyboard from the base of the laptop.
    • Be careful of the ribbon cables connecting the keyboard.
  12. Asus U56E-BBL6 Keyboard Replacement: passo 12, imagem 1 %32
    • Gently tug the ribbon cables free from their slots.
  13. Asus U56E-BBL6 Keyboard Replacement: passo 13, imagem 1 %32 Asus U56E-BBL6 Keyboard Replacement: passo 13, imagem 2 %32
    • Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
Conclusão
Josiah Allard
Membro desde: 10/26/18
733 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S2-G8, Peak Fall 2018 Membro de UMass Dartmouth, Team S2-G8, Peak Fall 2018
UMASSD-PEAK-F18S2G8
Membros da 3
Autoria de 6 guias
2 comentários
The Keyboard still has to be removed from the Top Case! Your not done yet!
philw395 - Responder
I removed the Keyboard from the Top Case and replaced the Keyboard. It wasn’t too bad with my Heat Gun and all-in-one painters tool…yes you heard right, my handy dandy painters tool that has served me well for years. Anyway, the only problem area taking the Keyboard out and snapping it back in (if you want to call it that) was by the DVD Player. Good Luck!
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 817
