Ir para o conteúdo principal
Asus U56E Laptop Screen Replacement
O que você precisa
  1. Asus U56E Laptop Screen Replacement, Screen: passo 1, imagem 1 %32 Asus U56E Laptop Screen Replacement, Screen: passo 1, imagem 2 %32
    • Position the laptop on a flat, stable surface, with the underside facing upward.
  2. Asus U56E Laptop Screen Replacement: passo 2, imagem 1 %32 Asus U56E Laptop Screen Replacement: passo 2, imagem 2 %32 Asus U56E Laptop Screen Replacement: passo 2, imagem 3 %32
    • Make sure the laptop is unplugged before removing the battery to avoid risk of electric shock.
    • Slide the two battery lock switches toward each other.
    • Lift the battery to remove it from the laptop.
  3. Asus U56E Laptop Screen Replacement: passo 3, imagem 1 %32 Asus U56E Laptop Screen Replacement: passo 3, imagem 2 %32 Asus U56E Laptop Screen Replacement: passo 3, imagem 3 %32
    • Remove the 3 Phillips #00 screws holding on the back cover of the laptop.
    • Lift the cover, exposing the laptop hard drive and RAM.
  4. Asus U56E Laptop Screen Replacement: passo 4, imagem 1 %32 Asus U56E Laptop Screen Replacement: passo 4, imagem 2 %32
    • Remove the eight small screws holding the hard drive in.
    • The hard drive cover can now be removed by lifting the tab on the left.
  5. Asus U56E Laptop Screen Replacement: passo 5, imagem 1 %32
    • Gently slide the hard drive left toward the edge of the laptop, then lift up to remove it.
  6. Asus U56E Laptop Screen Replacement: passo 6, imagem 1 %32 Asus U56E Laptop Screen Replacement: passo 6, imagem 2 %32
    • Remove the 4 Phillips #00 screws around the RAM.
  7. Asus U56E Laptop Screen Replacement: passo 7, imagem 1 %32 Asus U56E Laptop Screen Replacement: passo 7, imagem 2 %32
    • Remove the 10 Phillips #00 screws from the bottom of the laptop.
    • Remove 10 Phillips #000 screws from under the battery.
  8. Asus U56E Laptop Screen Replacement: passo 8, imagem 1 %32 Asus U56E Laptop Screen Replacement: passo 8, imagem 2 %32
    • Slide the optical drive out of the laptop.
    • Gently lift the rear plastic hinge cover to separate it from the laptop.
  9. Asus U56E Laptop Screen Replacement: passo 9, imagem 1 %32 Asus U56E Laptop Screen Replacement: passo 9, imagem 2 %32 Asus U56E Laptop Screen Replacement: passo 9, imagem 3 %32
    • Remove the 3 Phillips #000 screws from each side of the hinge (six screws in total).
    • Gently lift the thin plastic cover from each side, exposing the laptop hinge.
    • Be aware of the thin cables still connected to the screen.
  10. Asus U56E Laptop Screen Replacement: passo 10, imagem 1 %32 Asus U56E Laptop Screen Replacement: passo 10, imagem 2 %32
    • Gently lift around the perimeter of keyboard to separate it from the laptop body.
    • It may help to use a Plastic Opening Tool.
    • Be careful not to pull too hard on the keyboard - It's connected to the motherboard with a thin ribbon cable!
  11. Asus U56E Laptop Screen Replacement: passo 11, imagem 1 %32 Asus U56E Laptop Screen Replacement: passo 11, imagem 2 %32 Asus U56E Laptop Screen Replacement: passo 11, imagem 3 %32
    • Pull the display connector straight up to remove it from the motherboard.
    • Carefully detach the white and black WiFi antennas from the wireless adapter.
  12. Asus U56E Laptop Screen Replacement: passo 12, imagem 1 %32
    • The screen can now be safely removed from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
David Zilar
Membro desde: 09/29/15
167 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-5, Green Fall 2015 Membro de Cal Poly, Team 14-5, Green Fall 2015
CPSU-GREEN-F15S14G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 1,376
