Ir para o conteúdo principal
Asus U50F-RBBAG05 Hard Drive Replacement
O que você precisa
  1. Asus U50F-RBBAG05 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over so the bottom is facing up.
    • Slide the two tabs on the bottom of the laptop toward the edges of laptop.
    • Slide the left tab to the left to lock it into the unlocked position. The red showing next to the tab signifies that it's unlocked.
    • You will have to hold the right tab to the right to keep the slot unlocked while removing the battery.
  2. Asus U50F-RBBAG05 Hard Drive Replacement: passo 2, imagem 1 %32 Asus U50F-RBBAG05 Hard Drive Replacement: passo 2, imagem 2 %32
    • Hold down the tab on the right side, then begin sliding the battery out.
    • Remove the old battery.
    • Next, insert the new battery into the empty slot. Release the right tab to begin locking the new battery into place. Slide the left tab to the right to completely lock the battery into the slot. The red that was showing near the left tab should be gone. This signifies that the battery is locked into place.
  3. Asus U50F-RBBAG05 Hard Drive Replacement, Underpanel: passo 3, imagem 1 %32
    • Remove the six screws using a Phillips #1 screwdriver.
  4. Asus U50F-RBBAG05 Hard Drive Replacement: passo 4, imagem 1 %32
    • Pry the lower panel up with your fingernail or a spudger.
  5. Asus U50F-RBBAG05 Hard Drive Replacement: passo 5, imagem 1 %32 Asus U50F-RBBAG05 Hard Drive Replacement: passo 5, imagem 2 %32
    • Lift up on the panel and remove it.
  6. Asus U50F-RBBAG05 Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32
    • Remove the two screws using a Phillips #1 screwdriver.
  7. Asus U50F-RBBAG05 Hard Drive Replacement: passo 7, imagem 1 %32 Asus U50F-RBBAG05 Hard Drive Replacement: passo 7, imagem 2 %32
    • Using your finger, push the hard drive back.
    • Pry up the drive with an opening tool (or your fingernail).
  8. Asus U50F-RBBAG05 Hard Drive Replacement: passo 8, imagem 1 %32 Asus U50F-RBBAG05 Hard Drive Replacement: passo 8, imagem 2 %32
    • Pull back on the hard drive and lift upwards.
    • Remove the component completely.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Ao todo: 406
