Ir para o conteúdo principal
Asus Transformer Pad TF103C Speakers Replacement
O que você precisa
  1. Asus Transformer Pad TF103C Speakers Replacement, Speakers: passo 1, imagem 1 %32
    • Shut down your tablet before beginning the repair.
    • Insert the plastic opening tool on the side of the tablet.
    • Gently pull upwards and carefully pry open the tablet.
  2. Asus Transformer Pad TF103C Speakers Replacement: passo 2, imagem 1 %32
    • Slide the tool around all four sides of the tablet while gently pulling the tool up.
  3. Asus Transformer Pad TF103C Speakers Replacement: passo 3, imagem 1 %32
    • Remove the back cover once you have loosened it from the tablet. Set the back cover aside.
    • Rotate the tablet to match the picture.
  4. Asus Transformer Pad TF103C Speakers Replacement: passo 4, imagem 1 %32
    • Carefully unplug the rainbow cable from the motherboard.
  5. Asus Transformer Pad TF103C Speakers Replacement: passo 5, imagem 1 %32
    • Use the plastic opening tool to carefully pry the battery out from the frame.
  6. Asus Transformer Pad TF103C Speakers Replacement: passo 6, imagem 1 %32 Asus Transformer Pad TF103C Speakers Replacement: passo 6, imagem 2 %32
    • Use the JIS #000 screwdriver to remove the four screws.
    • Keep the screws together and organized. (Label the screws, if necessary).
  7. Asus Transformer Pad TF103C Speakers Replacement: passo 7, imagem 1 %32
    • Take the ground wire out from the top of the TF103C-L (left) speaker.
    • If you pull on the wire too much it will break off.
    • If you break the wire off you can solder it back on.
  8. Asus Transformer Pad TF103C Speakers Replacement: passo 8, imagem 1 %32
    • Remove the tape and unplug the wire that is connected to both of the speakers.
  9. Asus Transformer Pad TF103C Speakers Replacement: passo 9, imagem 1 %32 Asus Transformer Pad TF103C Speakers Replacement: passo 9, imagem 2 %32
    • Remove the two speakers from the frame.
Conclusão
Tyler Ellis
Membro desde: 10/28/15
668 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 3-6, Shastany Fall 2015 Membro de UMass Dartmouth, Team 3-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G6
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 454
