Introdução
This guide will lead you through the steps to replace the Transformer Pad TF103C Headphone Jack on your ASUS laptop. It provides you with detailed steps with pictures and requires few commonly used tools. If you follow this guide step by step, then you should be able to replace this part with little to no previous technical experience.
O que você precisa
Turn the power off.
Insert the plastic opening tool between the top and bottom covers of the laptop. The two covers are attached all along the outside of the laptop.
Gently pull upwards and carefully pry open the bottom and top covers.
