Ir para o conteúdo principal
Asus TUF Gaming FX705G Track Pad Replacement
O que você precisa
  1. Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: passo 1, imagem 1 %32 Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Track Pad Replacement: passo 2, imagem 1 %32 Asus TUF Gaming FX705G Track Pad Replacement: passo 2, imagem 2 %32
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Track Pad Replacement, Battery: passo 3, imagem 1 %32 Asus TUF Gaming FX705G Track Pad Replacement, Battery: passo 3, imagem 2 %32
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Track Pad Replacement: passo 4, imagem 1 %32 Asus TUF Gaming FX705G Track Pad Replacement: passo 4, imagem 2 %32
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Track Pad Replacement, Track pad: passo 5, imagem 1 %32 Asus TUF Gaming FX705G Track Pad Replacement, Track pad: passo 5, imagem 2 %32
    • Take the ribbon wire out of the track pad.
  6. Asus TUF Gaming FX705G Track Pad Replacement: passo 6, imagem 1 %32 Asus TUF Gaming FX705G Track Pad Replacement: passo 6, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the two screws holding the track pad in place.
  7. Asus TUF Gaming FX705G Track Pad Replacement: passo 7, imagem 1 %32 Asus TUF Gaming FX705G Track Pad Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Take the ground wire ribbon and pry it off of the motherboard housing with tweezers.
  8. Asus TUF Gaming FX705G Track Pad Replacement: passo 8, imagem 1 %32 Asus TUF Gaming FX705G Track Pad Replacement: passo 8, imagem 2 %32 Asus TUF Gaming FX705G Track Pad Replacement: passo 8, imagem 3 %32
    • Use the iFixit opening tool to pry the track pad up slightly at the top and pull the latch at the top to free the track pad.
    • Slide the track pad up and out of the housing unit.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 1,912
