Ir para o conteúdo principal
Asus TUF Gaming FX705G M.2 SSD Replacement
O que você precisa
  1. Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: passo 1, imagem 1 %32 Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G M.2 SSD Replacement: passo 2, imagem 1 %32 Asus TUF Gaming FX705G M.2 SSD Replacement: passo 2, imagem 2 %32
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: passo 3, imagem 1 %32 Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: passo 3, imagem 2 %32
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G M.2 SSD Replacement: passo 4, imagem 1 %32 Asus TUF Gaming FX705G M.2 SSD Replacement: passo 4, imagem 2 %32
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G M.2 SSD Replacement, M.2 SSD: passo 5, imagem 1 %32
    • Remove the Phillips #00 screw on the left side of the M.2 SSD.
  6. Asus TUF Gaming FX705G M.2 SSD Replacement: passo 6, imagem 1 %32
    • Gently lift the screw side of the SSD to approximately a 45 degree angle and pull away from slot to remove it from the laptop.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 38
Duração total: 4,105
