Introdução
If your device does not produce any sound, follow this guide to replace the faulty speaker.
O que você precisa
Disconnect the dock and make sure the power is turned off.
Use plastic opening tool to pry screen up and remove from outer casing.
Use a Phillips #00 screwdriver to remove the 3mm screws connecting the battery to the motherboard.
Use the same screwdriver to remove two 3mm screws connecting the clips.
Use tweezers to remove two wires connected from the battery to the motherboard.
Use the spudger to remove he battery from the case.
Uma outra pessoa concluiu este guia.
