Introdução
The front facing camera is protected by the screen but if the screen is broke , it might affect the front facing camera. A quick replacement of front facing camera can help the user in the future.
O que você precisa
Disconnect the dock and make sure the power is turned off.
Use plastic opening tool to pry screen up and remove the main tablet body from outer rim casing.
Be gentle with the plastic opening tool near charging port. The thinner plastic may break easily.
