Introdução
If your touchpad is glitching or is not responding to you, here is a step-by-step guide showing how to replace the ASUS ROG Zephyrus M15 GU502L touchpad.
O que você precisa
Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
Remove the 3mm screws that secure the touchpad using a Phillips #0 screwdriver.
Quase terminado!
Conclusão
