Ir para o conteúdo principal
Asus ROG Zephyrus M15 GU502L Touchpad Replacement
O que você precisa
  1. Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Battery: passo 1, imagem 1 %32 Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Battery: passo 1, imagem 2 %32
    • Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
  2. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: passo 2, imagem 1 %32 Asus ROG Zephyrus M15 GU502L Touchpad Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you separate the laptop cover from the side and run the tool along the edge of the cover to open it.
    • Be careful not to damage the cover when removing it from the laptop.
  3. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: passo 3, imagem 1 %32
    • Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
  4. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: passo 4, imagem 1 %32 Asus ROG Zephyrus M15 GU502L Touchpad Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the 8-pin battery that secures the battery to the motherboard.
    • Use the nylon tipped reverse tweezers to squeeze the edges, then pull out the connector.
  5. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: passo 5, imagem 1 %32
    • Remove the battery from the computer.
  6. Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Touchpad: passo 6, imagem 1 %32
    • Remove the 3mm screws that secure the touchpad using a Phillips #0 screwdriver.
  7. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: passo 7, imagem 1 %32
    • Remove the touch pad from the casing.
    • Be cautious picking up the touch pad as it is light.
Conclusão
Yahir Donis
Membro desde: 09/07/23
339 Reputação
Autoria de 2 guias
Equipe
Gateway, Team 69-69, Gonzalez Fall 2023 Membro de Gateway, Team 69-69, Gonzalez Fall 2023
GCC-GONZALEZ-F23S69G69
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 26
Duração total: 131
