Introdução
The ASUS laptop battery has been modified into a more compact form, making the battery not as accessible to easily replace. If your computer is not powering on even when connected to a power source. Here is a step-by-step guide of the ASUS ROG Zephyrus M15 GU502L battery replacement.
O que você precisa
Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
Quase terminado!
Conclusão
